Results 1 to 2 of 2
  1. #1
    Joined
    Jul 2012
    From
    Tennessee
    Posts
    2
    Default JS550 to bore or just hone and rings
    I have a 88 550 that was really hard to get started but ran really good when running. I did a compression check and it is down to 90psi. This engine is bone stock. I pulled the head and checked the bore at top and bottom. It is reading 75.08. Is this enough to justify boring the cylinders out or just hone and new rings? I plan on new crank seals while I have it apart. Is stock bore 75mm or 75.03mm. Thanks
  2. #2
    Joined
    Jun 2016
    From
    Clearwater, Florida
    Posts
    278
    Default Re: JS550 to bore or just hone and rings
    Stock is 75MM it sounds like it needs bored to an oversize.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Kaw 750 bore size-pistons and rings?
    By allsho80 in forum Kawasaki
    Last Post: 05-29-2008, 12:31 PM
  2. What grit flex hone.
    By jetcam2 in forum Sea-Doo
    Last Post: 02-08-2002, 12:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
