If they are original Kawasaki then they need to be bored out. They are cast in sleeves. If they have been sleeved before then you can press them out of the top after heating them in a oven.
I poured it and epoxy going to do the 44mm carbs at the timing advancement play and I'm going to try out the exhaust pulled all the baffles out of the muffler what you think I should get for top speed with this impeller
