LOCTITE type when mounting carbs back onto 1999 900 STX Kawasaki
  • LOCTITE type when mounting carbs back onto 1999 900 STX Kawasaki
    Appeared there was Loctite on factory bolts when pulling the carbs off the jet ski. What is recommended when this is reassembled wrt to LOCTITE type, to make sure it does not loosen, and still ensure I can pull the assembly off later with no issues. Torque required would also be valuable.
    Re: LOCTITE type when mounting carbs back onto 1999 900 STX Kawasaki
    Loctite 242
    Bolts going through flame arrestor and carbs? They are torqued to [0.80 kg-m, 69 in.-lb.]
