I just noticed that when I pressurize the tank by blowing into the return line, I see gas coming out the PTO return side but nothing out the MAG. There was flow a week ago and the only thing different I did was to replace the lines from the External fuel pump to carbs. The top nipple on the pump is where it is not coming from, however when I pulled the line off the pump, gas came pouring out, so obviously gas is getting to the pump but why not the carb???? Could there be a block in the carb????? What could be causing this????
Thanks chris
Thanks chris
