prop damage
  • prop damage
    i installed a scat-trac swirl prop that i had purchased for my 97 gsx and then took off and installed it on my 96 gtx. when running there was a lot of noise coming from the drive system.i removed the pump and found the prop to have a bend on one of the edges and a gash in the side of it with metal fillings on the wear ring.it was lined up on the shaft. what possibly could have caused this???
    TT
    Something went through the pump when you ran it. A stick or a rock probably.
    Bill O'Neal WCM
      it was on my trailer. i never put it in the water???
      TT
        Then I have no idea what caused it.
        Bill O'Neal WCM
