Hello Guys,did someone can tell me please the pop off pressure from my Carb. 98 Yamaha Venture 700. (WVT700BW).
Pop off Pressure?
Re: Pop off Pressure?
Right now not getting Gas??? Vacuum problem carb???After Carb. Clean and replace all Parts incl. needles and Setup the High Speed and Low Speed screw plus Pop off Pressure both Carb 34 PSI are setup.I can see on the inlet Gas filter before I start the Engine there is Gas inside, after the Engine runs there is no more Gas coming from the Tank to the filter.Its looks like the Carb. not creating vacuum.Anybody knows what can be wrong???
