Results 1 to 10 of 10
    May 2018
    Berryville
    5
    Default Yamaha SUV carb issues
    So bought SUV 1200 in pieces because he fried motor in 2013 so had it bored 50 over and put back together and rebuilt carbs carb jetting was not factory but they all cleaned up nice and did pop off test which they were all at 50 to 55 tried to fire up with no start until I put my hands over carbs closing vacuum off then it busted off but won't idle or restart without closing air off or keeping it reved up above 2000rpm. Is pop off pressure to high not letting fuel in? Carb air settings are at stock positions. I've added primer kit and a oil block off plate that's all besides bigger pistons.
    Jun 2016
    Clearwater, Florida
    279
    Default Re: Yamaha SUV carb issues
    Try setting the carbs at 38PSI pop off and see if it makes a difference.
    May 2018
    Berryville
    5
    So I pulled carbs and started to pressure test and heard a hiss come from vacuum port side and sprayed soapy water and the base of vacuum port is leaking so I'd assume I'd have a vacuum leak too, I matched gaskets with originals so could plates be warped or gaskets be thinner than original?
    Jun 2016
    Clearwater, Florida
    279
    When you say vacuum side I assume you mean the fuel pump side where the pulse fitting is. I doubt the plate is warped, but maybe some corrosion or a scratch on it. I suppose the gasket could be bad too, but I have used many different brands and not had a leak from a gasket.
    May 2018
    Berryville
    5
    Yes fuel pump side, and thing is it's from all three carbs in almost same spot so mabey gasket kit is cheap I did buy from flea bay�� I did check for deep scratches and made sure no gasket material was left behind, what carb kits do you recomend?
    Jun 2016
    Clearwater, Florida
    279
    We have put a lot of work into making our kits very good quality they are about $35.00 (1 kit needed per carb).
    https://www.shopsbt.com/jetski/mikun...ki-yamaha.html
    The other option is the original Yamaha kit which has all gaskets and needle/seats for three carbs, but its pricey at 263.67.
    Shop SBT W/ Cycle Springs Powersports 2002 Yamaha SV 1200A | CARBURETOR REPAIR KIT Parts List
    May 2018
    Berryville
    5
    Bought your kit and going through them now and noticed that all main jets were 135 and pilot jets went as follows stator side towards rear 100, 97.5, 95, why are pilots different sizes?
  8. #8
    Jun 2016
    Clearwater, Florida
    279
    I don't know why Yamaha does it that way.
    The service manual show #100 on Front, #95 on Center, #97.5 on Rear.
  9. #9
    May 2018
    Berryville
    5
    So I got carbs pop off pressures to 35psi, the ski starts great and runs great except when you shut it off after a ride then restart it will only except 1/4 throttle until it gains speed then you can go half to full throttle with no issues, you can idle around and take off with no issues. Could the pop off be to low and flooding the engine when it sits after ride or am I dealing with something else?
  10. #10
    Jun 2016
    Clearwater, Florida
    279
    It is not pop off, but the needle valve might be leaking.
  1. 1993 Yamaha VXR Issues
    By d3adlydesignz in forum Yamaha
    Last Post: 06-14-2017, 03:48 PM
  2. 94 Yamaha Pro Vxr Carb Issues
    By chingonejo in forum Yamaha
    Last Post: 03-13-2007, 07:44 AM
  3. Carb Issues?
    By xlt800_jan in forum Yamaha
    Last Post: 08-22-2005, 01:37 PM
  4. 96 780 Carb issues
    By taz in forum Polaris
    Last Post: 08-15-2005, 11:02 AM
  5. Carb issues 94 XP?
    By 94 XP-1 in forum Sea-Doo
    Last Post: 07-15-2003, 12:05 PM
