787 engine drops 500 rpm when held at about 5500...feather throttle and drop is gone....for a bit then returns...very regular....spark plugs different colours...brown/grey......thinking carb set up.also...specs say top rpm is 7200...i am at 6850....how is the rev limiter adjusted??
97 seadoo gtx
Re: 97 seadoo gtx
carbs done...new lines,needles and jets...problem still there....hold steady throttle...and rpm drops about 500 rpms....hit it a couple of time and they go back up....hold steady and they drop again.....is the rev limiter controlled by the computer???? issue does feel electronic...almost like someone flicking a switch....also...would a faulty rectifier cause these symptoms ????????????
