Final Bore Size 1100 STX DI
  • Final Bore Size 1100 STX DI
    What would be the final overall bore diameter if using the 1mm oversized SBT kit? Couldn't seem to find this spec anywhere... Thanks!
    Re: Final Bore Size 1100 STX DI
    80MM = standard size.
    81MM = 1MM oversized.
      Sweet, was just making sure!! Hard to put metal back lol...
        If you are boring and honing I would wait until you have the piston in hand.
        There are minor production variances.
          Ok well now I'm confused... What the tolerence then for ring clearances... What's the minimum and maximum vs recommended... Lot of play there for the machinist to make up for without knowing how loose or tight it should be... Really, variances in diameter?? I get weight but diameter variances... Maybe I should look at a different piston...?
            Does a data sheet come with these Pistons giving me this like a normal set of wisecos?
              Yes, it does.
