Results 1 to 7 of 7
    Jul 2018
    SC
    4
    Default Final Bore Size 1100 STX DI
    What would be the final overall bore diameter if using the 1mm oversized SBT kit? Couldn't seem to find this spec anywhere... Thanks!
    Jun 2016
    Clearwater, Florida
    278
    Default Re: Final Bore Size 1100 STX DI
    80MM = standard size.
    81MM = 1MM oversized.
    Jul 2018
    SC
    4
    Sweet, was just making sure!! Hard to put metal back lol...
    Jun 2016
    Clearwater, Florida
    278
    If you are boring and honing I would wait until you have the piston in hand.
    There are minor production variances.
    Jul 2018
    SC
    4
    Ok well now I'm confused... What the tolerence then for ring clearances... What's the minimum and maximum vs recommended... Lot of play there for the machinist to make up for without knowing how loose or tight it should be... Really, variances in diameter?? I get weight but diameter variances... Maybe I should look at a different piston...?
    Jul 2018
    SC
    4
    Does a data sheet come with these Pistons giving me this like a normal set of wisecos?
    Jun 2016
    Clearwater, Florida
    278
    Yes, it does.
  1. Max Bore size: 00 Ultra 150
    By jonwright in forum Kawasaki
    Last Post: 01-12-2010, 12:42 PM
  2. Stock bore size for a 650?
    By mikey2274 in forum Yamaha
    Last Post: 06-04-2007, 08:26 AM
  3. Piston size vs. Bore size?
    By Dragracer55 in forum Sea-Doo
    Last Post: 07-27-2006, 08:27 AM
  4. Stock bore size??
    By Cmobil12 in forum Tigershark
    Last Post: 07-08-2004, 01:09 PM
  5. BORE SIZE ON 650
    By HONEDOUT in forum Sea-Doo
    Last Post: 03-28-2004, 10:50 PM
