Hi I am trying to see if I bought the right rotary valve for my 97 Gsi 717cc.THe sbt part number is 420924502. When I compare the new one to my original, they are same diameter but there is more metal surface on the new one.The old one has more of a cut-out. For some reason I can't post photos right now. If I figure that out I will add one.
Rotary Valve Size
Re: Rotary Valve Size
The 1997 Parts microfiche calls out the following.
21 290924504 ROTARY VALVE (132°)
But the Sea-Doo specification manual calls out a 159 degree valve.
From what I have seen all 717/720 engines use 159 degree valves.
SBT# OEM# Description
45-101-01A 420924502 Rotary Valve SD 159 degree
45-101-01B 290924504 Rotary Valve SD 132 Degree
45-101-01C 420924508 Rotary Valve SD 147 Degree
