Seadoo xp 657 oil lines
  • Seadoo xp 657 oil lines
    Project ski. Is there 2 supply lines one to each carb? I have 1. the other line is blocked off?
    Sent from my SM-J700T1 using Tapatalk
    Re: Seadoo xp 657 oil lines
    There should be one line to each carb.
      Thank you. Will the oil tank with supply line and return hose be enough oil bath for the lower engine and R.V.? oil pump blocked off.
        It is enough for the Rotary Valve shaft only.
        The crankcase needs to be lubricated either by the oil injection lines or by a premixed fuel.
