I have a 02 Seadoo GTX RFI with 110 Hours on it. After Replacing the Battery, it was full charged 12.8Volt I drive the ski on the water. After 1 Hours its shows "12V Low". Checked Battery and was 12.2 Volt. After Charging the Battery over night, take the ski to the water same happens after 1 Hours ride "12Volt Low". After searching in some forums, it can be the Recitifer. I bought one on Amazon, trying to installed and always if plug the Recitifer the 20AMP Fuse will blown. Plug the old Recitifer back and the Fuse are not Blown. What can be the Issue?
02 gtx rfi low 12 voltage alarm
Re: 02 gtx rfi low 12 voltage alarm
We have OEM Rectifiers (278001554) in stock for $182.99
We have the SBT aftermarket version for $115.45
https://www.shopsbt.com/jetski/sea-d...278001969.html
Why don’t you return yours for a replacement?
You said you just purchased it didn’t you?
