waverunner 1200xlt 2001 power valve not opening and cant go above 6000rpm
  • waverunner 1200xlt 2001 power valve not opening and cant go above 6000rpm
    Hi, I rebuilt my engine and with all genuine parts from SBT, starts well, idealing is prefect, run in is complete, but I cannot seam to get more then 6000 RPM. I took off the engine cover and rode it and noticed that the power valve is not opening at all, once I switch the engine off then the power valve opens and closes. what could be he issue? thanks
    Re: waverunner 1200xlt 2001 power valve not opening and cant go above 6000rpm
    Hi anyone out there that can advice me? thanks
      If it cycles when turned off it suggests it is working. If it is not operating while engine is running it is possible that the CDI is not seeing the engines RPM's. Check wire harness between CDI and Servo motor for loose connections, frayed wires, or corrosion.
        thanks, please tell me what is CDI?
          CDI = Capacitor discharge ignition.
          It is the "brain" controlling ignition.
