Results 1 to 8 of 8
    Jun 2018
    Reisterstown Md
    94
    Default 95 sts 750 impeller shaft spinning after much debris in the river. Logs sticks bark s
    While crossing the Potapisco river debris in the river multiplying until 750 sts started losing propulsion. Turned around and limped back to boat ramp keeping rpms at under 4x . anything over that the impeller just spinning. Made the mile and a half back. Pulled pwc from water and see sea grass inside jet pump. although nothing noticeable at grate intake? If impeller gets filled with debris what is possibly broke and how should I troubleshoot it. I never turned off ski to reset anything could my Sts 750 have put itself in limp mode because it never overheated just would not propell the pwc beyond 4x rpms . Please tell me what to check first? Should I have restarted the ski to see if propeller is turning when wick is pulled over 4x rpms? please respond
    Sent from my SM-J700T1 using Tapatalk
    May 2018
    Lake Travis, Texas
    8
    Default Re: 95 sts 750 impeller shaft spinning after much debris in the river. Logs sticks ba
    Start by removing the sea weed then check the impeller for any dings or cracks or bends, and then check the wear ring for scratches. Iím thinking the seaweed was probably causing a significant amount of cavitation at high rpms, and if the impelled is clean it should work fine after all the seaweed removed
    Sent from my iPhone using Tapatalk
    Jun 2018
    Reisterstown Md
    94
    Is there a wear ring in a 1996 Kawasaki sts 750?
    May 2018
    Lake Travis, Texas
    8
    I have no idea, if it were mine I would definitely start with removing the seaweed and seeing if that helps or solves it. I donít know if it has a wear ring, Iíve never actually seen one of these skis.... I would start simple and if the simple things donít fix it then go from there
    Jun 2018
    Reisterstown Md
    94
    Thank you. I limped back and have not restarted it yet. Maybe it put itself in limp mode. but anything over 4x rpm was cavitation. spinning. Worst case is stripped splines. Thank for your Good words.I was at Calvert cliffs yesterday. Picked up a 2001 rx D.I hull with everything except engine and jet pump..
    May 2018
    Lake Travis, Texas
    8
    I donít think it would be limp mode if it could still go above 4K rpms but would just cavitation at that speed. Limp mode would be more likely if the engine was overheating and it was limiting the rpms to 3-4K without being able to go any higher because it was trying not to overheat any worse...
    Jun 2018
    Reisterstown Md
    94
    I did as you suggested. Thank you. I had a plastic bottle cap stuck on the impeller blade. Pulled it off. Hooked up flush hose. All clear. could that have caused the cavitation? We were about 100 yards away from fort Mchenry. its like a mine field in that area. logs trash everywhere. A bad choice that could have cost a bundle.thanks for reminding me to keep it simple and look for obvious reasons first
  8. #8
    May 2018
    Lake Travis, Texas
    8
    I had a small twig cause huge cavitation with my ski so I wouldnít doubt a bottle cap causing issues. If you havenít already you might look into installing a strainer in your engines water intake to keep some trash from clogging cooling if trash is a big issue on your riding area... thereís an argument for it and against it so read up on it before you do it.
  1. ďDebris CleanoutĒ access plug removal
    By Frankjr57 in forum Yamaha
    Last Post: 06-22-2010, 10:19 AM
  2. steering sticks on my 94 750 sl
    By adams95 in forum Polaris
    Last Post: 06-13-2006, 12:24 PM
  3. 94 sp impeller shaft
    By ryan a in forum Sea-Doo
    Last Post: 06-19-2005, 09:08 PM
  4. Debris in pump......again
    By BertinTexas in forum Sea-Doo
    Last Post: 08-23-2004, 01:08 PM
