Results 1 to 2 of 2
    Jun 2005
    florida
    65
    Default SeaDoo 4Tech Idle Fluctuation
    2002 SeaDoo GTX Limited with about 300 hours. Original motor, compression test shows 155 on all three cylinders. When at an idle the RPMs fluctuates up and down between 2500 to 3500. Put new NGK spark plugs in, still the same
    Mar 2019
    CLEARWATER, FL
    5
    Default Re: SeaDoo 4Tech Idle Fluctuation
    I'd put fresh gas in it. If that doesn't fix it then its possibly the throttle body air intake section that needs to be cleaned.
    SBT TECH DEPARTMENT
  1. 2002 SeaDoo GTX 4-Tech Idle Fluctuation
    By 8kgold69 in forum Sea-Doo
    Last Post: 10-21-2018, 11:40 PM
  2. 2011 seadoo gti130 idle 3 sec then die
    By zouzou_837 in forum Sea-Doo
    Last Post: 11-01-2017, 09:50 AM
  3. 2001 seadoo gtx will not idle
    By Jaylu359 in forum Sea-Doo
    Last Post: 06-27-2011, 02:15 AM
  4. Oil recommendation for 2004 GTX 4Tech
    By coach mike in forum Sea-Doo
    Last Post: 07-06-2005, 11:59 AM
  5. SEADOO IDLE PROBLEM
    By DCHOPPERZ1 in forum Sea-Doo
    Last Post: 02-18-2004, 01:23 AM
