Results 1 to 6 of 6
Thread: 97 seadoo gsx
  1. #1
    Joined
    Dec 2018
    From
    Broksville
    Posts
    4
    Default 97 seadoo gsx
    What up errr body 97 gsx sat for 6yrs rode about 3 times . rebuilt carbs after ultrasonic cleaning, new battery. No turn over (no start) new plugs. Little red light comes on - no dash lights. tried the key-off start button 5x's thing ; same outcome. Jumped solenoid starter spins but doesn't engage (figure rubber mallet might fix that) please help just wanna ride again. Thks
  2. #2
    Joined
    Jun 2016
    From
    Clearwater, Florida
    Posts
    278
    Default Re: 97 seadoo gsx
    Do you get chirps when the DESS key is installed on the DESS post?
  3. #3
    Joined
    Dec 2018
    From
    Broksville
    Posts
    4
    Nope just the little red light
  4. #4
    Joined
    Dec 2018
    From
    Broksville
    Posts
    4
    OK !! from battery to MPEM hot wire is hot. Coming from MPEM to Start switch HOt wire is hot. When I press Start switch that HOt wire turns negative. Could this be the MPEM??
  5. #5
    Joined
    Dec 2018
    From
    Broksville
    Posts
    4
  6. #6
    Joined
    Nov 2017
    From
    Cameroon
    Posts
    1
    Default -
    I have a SEADOO GSX 800 that wont start in the water. It starts and has no problem with compression out of water. I can even sometimes get it to start after its been out of the water and run it in the lake but as soon as I stop and try to restart it does the same thing. The starter starts to engage and then lets loose like it thinks it has started. It will turns over a half to one time then the starter makes its whining noise. NEVER doers that out of the water only in the water. Is the starter shot?
    ascania-nova site
Thread Information
Users Browsing this Thread
There are currently 2 users browsing this thread. (0 members and 2 guests)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
