Results 1 to 5 of 5
    Mar 2019
    Tampa
    4
    Default 100 STX Speedometer not reading correctly?
    Hello, I am new to the forum section here and this is my first post.
    I have a 1998 STX 1100 that I've recently purchased. I've had to replace the electronic gauge cluster (no display). After replacement with a used one on ebay I discovered the speedometer was not working and stuck on 0 MPH, so I replaced the speed sensor. (also from ebay)
    Using compressed air, I can get it to read in excess of 20 MPH. However on the water it will not display over 6 MPH, when I know I'm at least doing 30. Any advice would be greatly appreciated
    May 2018
    Lake Travis, Texas
    8
    Default Re: 100 STX Speedometer not reading correctly?
    Check and make sure that itís spinning freely, and itís adjusted correctly, the wheel might not be touching the water.
    Sent from my iPhone using Tapatalk
    Mar 2019
    Tampa
    4
    It does spin freely. Im not aware of any possible adjustments that can be made. It seems the sensor should be moved down to contact the water more when on plane. I feel like it's working properly when at idle or low speeds, but this ski has no trim.
    Sent from my SM-G950U using Tapatalk
    Mar 2019
    1
    Quote Originally Posted by Jakber. View Post
    Check and make sure that it’s spinning freely, and it’s adjusted https://asean-wen.org/phenq-reviews/ correctly, the wheel might not be touching the water.
    I Also It seems the sensor should be moved down to contact the water more when on plane.
    Mar 2019
    Tampa
    4
    I actually figured it out. It did need to be moved down, but it only had about 1/8 inch movement. Had a buddy push down on it while I tighten it. New layer of silicon and I'm golden. Thanks for the replies!
  1. New Starter will not seat correctly
    By usf in forum Yamaha
    Last Post: 06-04-2012, 10:11 AM
  2. Replies: 1
    Last Post: 07-30-2010, 10:00 AM
  3. Replies: 2
    Last Post: 07-29-2010, 03:01 PM
  4. Did I winterize correctly?
    By The Grayt 1 in forum Sea-Doo
    Last Post: 12-01-2004, 09:12 AM
  5. My SBT motor won't start or run correctly....
    By OrlandoPWC in forum Yamaha
    Last Post: 05-08-2004, 12:15 AM
