1999 GTX Limited 951 Carburated
  • 1999 GTX Limited 951 Carburated
    Afternoon! I have a 1999 GTX Limited that has a high idle; around 3700 RPM's. The idle screw is backed all the way out, and i used carb fluid to test the gasket for air leaks. I've also rebuilt the carbs, and made sure to use the same springs i took out. Any ideas on what could cause a high idle?
