Jet ski is bogging down HELP!!!
  • Jet ski is bogging down HELP!!!
    I have a 2001 Yamaha GP800R and it has great top end but when i gas it sounds as if its about to stall. It just grumbles and doesn't move anywhere but if i feather it i can get it to 15 mph then it will take off. I don't know if its a carb issue but i was reading a thread and they talked about a wear ring that was bad and they get no low end but it sounds as if the engine doesn't give of power in the low end.
    Re: Jet ski is bogging down HELP!!!
    Is the Powervalve controller working ? Its called YPVS.
    This has a major part to play at takeoff speeds.
    You can hear it going thru its back+forward operation when you stall the motor.
    Additionally, when was the last time you serviced the carbs ?
    No matter how well you freshwater flush the motor exterior after use Salt water corrosion can be worse than you think.
    Sent from my SM-N950F using Tapatalk
