Floating Ring Tool no longer available from Seadoo
  • Floating Ring Tool no longer available from Seadoo
    What are you guys using to remove the driveshaft from a 2013-2017 GTR or RXP now that Seadoo no longer makes the floating ring tool needed to remove the circlip and pop the shaft?
    Tool is 529036116.
    Tool 529036941 while it has the finger spacing correct (narrow), it will not fit over the shaft or collar (GTI models).
    Tool 529036987 will fit over the shaft and collar but the finger spacing is too wide (RXT models)
    You call into Seadoo and it is like their first time learning the tool is not available and will try and push the above two tools on you as being the correct ones.
    David
    David B. Thomas<br />Blew-By-You PWC Services<br />93-A Pine Burr Rd<br />Lumberton, MS 39455
    Re: Floating Ring Tool no longer available from Seadoo
    Tool is 529036116.
    David
    HI David,
    Did you ever find the solution to the right tool? I just took my 2013 RXT-X apart tonight and found the same issue. I bought the 529035987 as I thought I saw it was the replacement but you are spot on, the spacing is way too wide, I cannot get it small enough. Right now, I'm stuck
    Click image for larger version
      Cubestore.org - your stable dumps &amp; cvv provider
      CUBESTORE.ORG - YOUR STABLE DUMPS & CVV PROVIDER Dear bros, We want to inform u that our store has opened! With us u can always find the highest quality and freshest stuff! DUMPS & CVV & NOCVV CARDS! Our mirrors: WEB: https://cubestore.org TOR: http://cubesnmkjidbuivo.onion BIT: http://cubestore.bazar Tags: CUBESTORE.ORG - Dumps shop, track1, track2 cheap dumps. You must buy cvv and buy dumps on our carding shop. buy dumps, fresh dumps, cheap dumps, valid cvv, checker cvv, dumps cvv, fullz, nocvv cards, credit and debit cards buy
