Check Ground strap connection or install additional ground cable to resolve numerous issues.
2005 FX Cruiser
Re: 2005 FX Cruiser
Yamaha FX Ground Issue, YouTube.com/watch?v=MzkktBZUCBs
Yamaha FX Cruiser would not start up without grinding the starter. It fired up after several attempts, On Trailer I tested the Fuel pump Circuit and found the Positive feed was active, I checked ground feed was intermittent and added 2nd Ground wire from Battery to engine on the Oil cooler, I added additional ground wire from Fuel pump ground wire to the Oil cooler ground cover bolt. I checked YDS data and no fault found or recorded.
Manual makes no mention of loss of ground and is over looked due to checking for feed to components tester is always from Negative Ground either on Battery or on Engine Block.
Check Negative feed from Component wire back to Positive feed of Battery You'll Find if Loss of Ground has occurred.
Re: shoutbox
Originally posted by itasomI am new user and i would to ask you. If i want talk with use shoutbox - it is possible? :)
