So I setup a tool to check my pop off pressure. I have the 38 Mikunis off my 95 Waveraider deluxe 700. My pressure is popping off at 29psi on the carb with pump. When I try to test the front crab without pump, my pressure goes pass 30 which is max on my gauge. Soon as I let off pumping air, it drops pressure immediately. So I’m around 50ish psi and the carb isn’t doing anything. I had WD-40 on the needle/Seat. No bobbles, etc.. I’m using an old spring, new spring. Is there something clogged up inside carb?
Also, I’m not sure if all my front carb without fuel pump just has o-ring and cover or there is a rubber sheet over the o-ring on the carb.
