it could be a weak spring for the needle and seat and you also want to check your fuel pump diaphrams
left turn bog
The diaphrams in the carbs are facing the wrong direction. They need to face forward or back.
Centrifical force is acting on the diaphrams when turning hard in the corners, cutting off the fuel supply.
There are ways to counteract it, by changing nozzel sizes, impellor pitches, ect, but none of these "patches" really fix the lean fuel problem when cornering. What you cannot hear or feel, is the detonation that occurs when turning (heavy loading of the motor).Bill O'Neal WCM
