not sure how to explain this but ill try have a 93 sp project ski im working on ,pulled heads pistons look fine,well the whole motor looks great for a 93 un touched,when i split the crankcase i found my problem instantly now heres where i not sure on one of my rods thebearings are shot other is fine but according to microfiche you cant buy them or can you? i know the other parts have to be pressed,and i do know some one that will press it or do ijust need a new crank? thanks
connecting rods
you would be better off with a new crank because once you press the crank you need to make sure that it is true and still in phase.
Also, make sure your pistons are ok. Usually when a bearing goes out it damages the piston and/or head.SBT Tech Support is here to help with your problems.
