I had a bad leak on my 94 spx. Oil all over the hull after a few days. I removed the oil pump and installed a block off plate and changed the oil bath lines. I haven't seen any oil in the bottom yet. The nylon gear had a bad/melted part where it sealed against the pump. The question is my oil bath level is dropping a little with each run (only had 2 so far). At first I thought it was air in the block that got pumped out when it was run the first time with out the oil pump. I haven't seen any oil in the hull so do you think the crank seals are leaking while the motor is running because of the vaccum? It's run about 1.5 hours so far and dropped about an inch in each side of the line. I revmoved the oil tank and just attached the lines together. Do you think the oils not leaking out while sitting because of the vaccum that would be created when it leaks?
Chad
Chad
