any ide what happen ?? when i acelerate the xpl it die it turns on perfectly the plugs are new i see dirt on the fuel filter i clen it but it has the same thing what you think it its the carb need to be clean or the fuel tank ? or both?? or there are other problem causing this helpme
xpl 98 die when accelerate
clean the carbs and maybe siphone this gas out, also keep an eye on the filter once you have cleaned it all up so that you can catch most of the stuff there before it gets to the carbs, but if you keep having a lot of things in that filter you may have to do the carbs again
After you clean the tank out and all 3 filters, add an inline fuel filter into the fuel line between the sediment bowl and the carbureators. Make sure the accellerator pump nozzels are squirting gas as they should.Bill O'Neal WCM
