got a couple a questions on sbn carbs. what i need to know is if the low and high speed adj are the same in a sea doo 38mm and a 40mm "I" series carb?
secondly, on a dual carb 720 (96spx), are the carbs the exact same if all parts are removed? i am using a mag side carb from the setup and looks identical to the pto carb but am having the most undesireable time trying to get it tuned to my custom project and i needed to know if there is any tiny detail about the two carbs that isn't obvious to the naked eye? they both have built in restrictors and the such...................cleaned to hell and rebuilt using mikuni new parts on everything but i lost the adj needles and used ones from a 38mm setup i had and was just wondering if there is a difference?
