Oil Pump adjustment/alignment
  • Oil Pump adjustment/alignment
    On a 787 oil pump, when the engine is at idle, the 2 lines should be lined up correct? Mine are off about 1/8", if I have to pull the throttle a hair they line up. This would me that there is not enough oil mixing with the gas correct?
    thanks
    Correct.
      thanks, will make necessary adjustments. My father's is off too then.
        Not Correct.
        If there is slack in the throttle cable, the mark should be slightly behind the mark on the pump body so that when you pull the throttle lever, the lines cross at the same time the butterflys start to move when the slack in the cable is gone.
          I'm pretty sure I don't have any slack, I even look at my thumb throttle, I can see carbs start to open. Not sure on my father's though. If there is no slack, that would make the oil pump off correct?
            He didn't say anything about slack. If the cable is tentioned properly, I'm correct.
            Yes the alignment needs a proper idle speed and slack adjustment.
              The service manual describes the proceedure for adjusting the oil pump and it pretty much states what I posted eariler.
              To check for slack, move the throttle lever and see how wide the gap is between the throttle lever and the lever housing. If it moves at all without moving the throttle plates, it has slack in the cable, which it should have some slack in the cable.
