Results 1 to 6 of 6
    Sep 2003
    Tampa, Florida
    57
    Post
    I hate to bring the same old subject up - because it actually is talked about so much, it should prolly be made into a faq [img]smile.gif[/img] -
    I was out at Lake Seminole this weekend and a buddy of mine flipped my 97 XP over. He flipped it back over clockwise, and couldn't get back on it - it just kept flipping back over. So, he sat tehre until someone could bring him back and tow the machine back....
    When we got back (it was at the end of the day) I trailered both skis, did this
    1. Shot water out of cylinders for a little bit
    2. Took off the ignition box and dumped teh water out.
    3. bought new plugs
    4. brought it home and got it started on the first set of new plugs.
    5. Flushed it for about 10-15 minutes (on idle with a little blips of the throttle)
    6. After reading something from bill@watercraft - throttled and rev'd high a for a few minutes to try to suck any water out of the crankcase.
    This was last night, the ski was actually starting better than it did before the flip ironically. I do have Yamaha Fogging Oil for my Yamaha, but I know the difference between viscosity in SeaDoo and Yamaha oil, I didnt know if the fogging oil was the same so I didnt use it. Now this morning after reading I wanted to take it back over to the lake to run it hard again to get any water out of any places it shouldnt be - but wanted to know if it is too late, and prolly won't make a difference.
    I was going to WD-40 everything, and just protect what I can.
    For what it's worth, a friend of mine did this with s 96 gtx and it took him ALOT longer to get it started then mine. Once I put the new sparkplugs in it started on first try.
    What should be done at this moment? Without running it hard in the lake, did I destroy the crankbearings?
    Help! [img]smile.gif[/img]
    [ October 20, 2003, 10:07 AM: Message edited by: bamboo ]
    <a href="http://www.flyerfaucet.com">
    Flyer Faucet Printing Services
    </a> Worldwide Leader In Full Color Printing
    Feb 2001
    Glendora, Ca.
    5,204
    Post
    You did the right things and no permanate damage should be done. Next time, use any fogging oil or WD40 that you have available. The oil does not know that it is going down a Sea Doo carb or a Yamaha carb [img]smile.gif[/img]
    Go ride the ski for at least 30 minutes ASAP.
    Bill O'Neal WCM
    Sep 2003
    Tampa, Florida
    57
    Post
    Perfect - Did that. People at work REALLY didnt believe that I was going out on the ski because I HAD to....
    Ironically it almost runs better then before. (Prolly the new plugs maybe?)
    21,545
    Post
    We have had a video on the subject for some time in the Videos section.
    Gold Coast Australia
    140
    Post
    Its a good idea to remove the plug from the top of the balance shaft gear cavity and spray a can of lube into it, start it and let the gear rooster all the white oil/water emulsion out.
    If the rear balance shaft bearing fails due to corrosion, it usually takes the cases with it.
    On non suspension models, you can remove the plug on the bottom and drain the cavity. Too hard on 79xp's.
    Jan 2002
    Morgan city La.
    323
    Post
    Guess you realize that your first mistake was letting your friend ride it. Best friends and pretty girls will always wind up screwing up your boat somehow. they'll always feel really bad, but your the one stuck having to fix it.
  1. Please Help . Water inside a 650 Kawa Engine
    By clydewater in forum Kawasaki
    Last Post: 09-15-2005, 08:32 PM
  2. Water inside a 650 Kawasaki
    Last Post: 09-12-2005, 04:29 PM
  3. Tigershark Monte Carlo 1000 - Water :(
    By redr2 in forum Tigershark
    Last Post: 09-28-2004, 09:30 AM
  4. interesting theory on water injestion on 951
    By BEECHFRONT in forum Sea-Doo
    Last Post: 09-13-2001, 08:23 PM
