Results 1 to 4 of 4
Thread: flywheel
    Feb 2003
    cocoa florida
    167
    Post
    can a flywheel out of a 99 or later 951 still work on a 98 951?i have read they changed the ignition system in 99 but i thought you could use the same flywheel but had to just replace the magneto.
    tom
    TT
    21,545
    Post
    There isn't a direct model year change over. The part number is stamped on the flywheel, or you can look at the magnet layout - as long as they match, you can use it.
    Jul 2001
    Omaha, NE
    88
    Post
    I am pretty sure 99 is when they went to a set up to fire spark plugs individually instead of both at the same time, so no, 99 would not work in 98 unless you changed over the pick-up and MPEM as well.
    Griz
    Gold Coast Australia
    140
    Post
    the flywheel will work, but the magnet hub will not. the 99 has too many lumps on it.
    If you are using 98 hub on 99 f/wheel, mark the pickup lump position in relation to the flywheel key slot and duplicate on the 99 f/wheel. The factory locator hole is different.
    If the hub is broken on your ski, you can use a hub off an 800 as they are the same.
  1. 580 Flywheel Identification
    By RZMike in forum Sea-Doo
    Last Post: 06-22-2007, 11:11 PM
  2. pulling off 787/800 flywheel
    By radiocontrolhead in forum Sea-Doo
    Last Post: 10-03-2005, 12:24 PM
  3. Replies: 4
    Last Post: 10-02-2004, 02:25 PM
  4. Flywheel Removal, bad break
    By cat770r in forum Tigershark
    Last Post: 04-24-2004, 07:05 PM
  5. Flywheel Broke?
    By avlnche in forum Polaris
    Last Post: 07-03-2003, 02:55 PM
