I have a 1999 sea doo speedster, I am going to rebuild my carbs, the left engine stalls at normal idle at engine temp of cold or hot. If you keep the RPMs 3000 or above no problem.
My question is, do you need to check the pop off pressure, if your are doing a strait cleaning rebuild, no modifications? If you don't let the boat idle below 3000 too long, the boat transitions from idle to full throtal flawlessly, it has fairly good power, jumps right on plain.
Does the SBT kit contain factory set springs?
