I have spent hours searching here on how to solve my fuel guage problem.... i found some great advice, but usually it always came down to BUYING A NEW BAFFLE !!!!!....
1st.... it worked fine last trip....!!!!!
2nd.... then after a long bumpy road trip to a far away lake.....no guage at all.....
(((depressing starter button to power up guage would only read at the bottom of red))) tank had 5+ gallons in it...
3rd.....lots of searching here to find a fix
4th.....went to local Honda--Sea Doo shop to ask to see a baffle up close... $$$ 121.00 for new baffle.....!!! then the shop guy informed me of something !!!!!!!!
HE HAD THE FLOAT FOR SALE SEPERATELY !!!
Part #275 500 348 $ 9.21
5th ..... i bought it hoping it would work !!!!
6th..... drained gas tank
7th ..... removed all straps and propped oil tank up with bungee cord
8th..... loosened filler and baffle connection to gas tank
9th....performed contortionist move to get tank out of hatch W/O disconnecting any small hoses to baffle....success....!!!!!! [img]graemlins/uts.gif[/img]
10th...pried up plastic at bottom of baffle being careful not to trash it .....
11th... slid old float out (((NO MAGNET TO BE FOUND ANYWHERE))))
12TH.... slid new float inside baffle and checked to see if it worked in different positions by powering up the guage....
13th... IT WORKED !!!!!!! :D :D :D
14TH ... MADE SURE NO GAS WAS ANYWHERE TO BE FOUND IN GARAGE !!!!!!!!!
15TH... PUT A HOT FLAME TO A SCREWDRIVER ((far away from garage)))AND HOT WELDED BAFFLE BOTTOM back TO BAFFLE..................ZERO glue needed....
16TH.... re installed tank after inspecting it completely((no cracks))...put on straps and connected all hoses to origional positions...
17th... filled gas tank... depressed power up switch...... :D
FOR LESS THAN TEN BUCKS IT IS FIXED !!!!!!
18TH...DRANK MORE BEER [img]graemlins/spit.gif[/img] [img]graemlins/spit.gif[/img] [img]graemlins/spit.gif[/img]
TOTALLY HAPPY THAT I'M NOT PUTTING UP WITH HAVING TO REMOVE MY SEAT TO CHECK THE SLOSH IN THE TANK ANYMORE!!!!!!
very happy to post this here with the hope that someone else will solve their problem with very little effort and little cash !!!!!
LESS THAN 40 MINUTES OF ACTUAL WORK
