Greetings. I have a 95 GTX with a bearing that seized up on me about 2 weeks ago. Since the engine was out of warranty, I decided to replace it with an SBT short block instead of replacing the crankshaft. I've also replaced the starter with an OEM part.
Once the new engine was back together, it turns over without a problem, but I'm not getting any spark on the plugs. I've changed the plugs, put a new battery in, and did some basic troubleshooting with regards to gas flow to the engine.
I'm thinking there is a problem with the stator, magneto, or electrical system in the unit. (This ski was working for several years and was working as recently as 2 weeks ago…)
Is there a way to pinpoint where the problem is before I rip apart the flywheel, etc. and start looking around for loose connections? Is there some kind of tool I can purchase that tests charge coming from the flywheel assembly to the electrical box from the male/female connection on the outside of the flywheel enclosure?
Does this particular model have fuses that I should be looking at as the next logical troubleshooting point?
I was very careful when I put the new engine in, and the electrical panel was never even touched. Is it possible something shorted out? (This is not the first engine I've installed by myself in this unit...)
Any suggestions would be greatly appreciated...
