exhaust leak
  • exhaust leak
    hey guys...getting a tiny bit of water leaking from the exhaust ....take a look at the pic and tell me if it is anything to worry about or should i replace the gasket.....???? if so how hard is it to do??
    if you have water leaking there , replace the gasket , if it leaks inside the motor you will be rebuilding it soon if you dont fix it asap .its a very easy job and the parts should be under 10 bucks . you can get the gaskets from SBT .if you need help just ask :)
      it seams like all i need to do to get to it is unscrew 4 bolts and detach the exaust pipe from the water box and replace the gasket???
