THERE ARE 34 IN 717 IS THAT CORRECT
96 SEADOO GTI 717 ROTAX
I AM TRYING TO PATCH THIS ENGINE FOR THE SUMMER THEN I AM REPLACING IT WITH AN SBT REMAN SO I AM TRYING TO KEEP ANY AND ALL EXPENSES TO A MINIMUM I HAVE BEEN DONATED A USED GOOD PISTON AND RINGS. IF I CAN RETRIEVE ALL THE NEEDLE BEARINGS I BELIEVE IT WILL WORK THE RD LOOKS GOOD AND THE BEARINGS LOOK GOOD. I SIEZED #1 WRIST PIN TO THE PISTON. I HAVE ANOTHER QUESTION MY SKI 96GTI HAS A HOSE THAT GOES FROM THE UPPER REAR ALL THE WAY TO THE FRONT OF THE ENGINE BUT IT IS LOOSE AND LAYING ON THE BOTTOM. DO YOU KNOW WHERE THIS CONNECTS.
the hose is prob the battery vent hose if you have not found out what it was yet . you can use a shop vac with a small hose on it to suck out your case , but for time and expence needed to do the topend you should just do the rebuild the right way now .your only going to add about 3 hrs to the job .PRIDE IN SERVICE<br /> <img src="http://www.sbtontheweb.com/images/forposts/4609/1.jpg" alt=" - " />
