I HAVE MULTIPLE QUESTIONS . WHAT IS NORMAL COMPRESSION READINGS FOR THIS ENGINE? HOW MANY NEEDLES ARE IN THE WRIST PIN BEARING? AND WHAT DOES THE LONG VACUMN TYPE HOSE THAT RUNS FROM THE REAR OF THE SKI ALL THE WAY UNDER THE ENGINE HOOK INTO AND WHAT IS ITS FUNCTION IT IS CONNECTED AT THE REAR BUT IS LAYING ON THE BOTTOM BY THE ENGINE ? SORRY NEW TO SKIS THANKS FOR ANY HELP
96 SEADOO GTI 717 ROTAX
Compression should be around 145. I don't recall, I think 36 needles? If you mean the tube that loops up then down, that is the siphon tube, to remove water from the ski while moving.SBT Tech Support is here to help with your problems.
SORRY ABOUT THE BARRAGE OF QUESTIONS JUST LEARNING. I WANT TO PREMIX MY OIL AND FUEL WHAT IS THE PROPER RATIO FOR THIS SKI. I HAVE A FEELING THE LACK OF LUBRICATION HAS CAUSED THE #1 WRIST PIN TO SIEZE AND I DO NOT WANT TO GO THROUGH THIS AGAIN. I AM PATCHING THIS ENGINE FOR THE SEASON THEN I AM BUYING A REMAN FROM SBT IN AUGUST
THANKS.SHOULD THE TUBE BE LAYING ON THE BOTTOM UNPLUGGED? 36 NEEDLES CONCERNS ME I HAVE TAKEN THE CYLINDERS OFF AND FOUND #1 WRIST PIN SEIZED. I PRESSED IT OUT TO FIND SEADOO DOESNT HAVE A ROLLER CAGED BEARING I HAVE RETRIEVED 30 NEEDLES??
