Well I thought everything was running great. I used the ski last Tuesday and then it sat in the water until today, when i fired it up to ride it. I got out on the water and was at WOT and then it seemed to bog down and try to die. I let off the throttle and it idled fine, then it didn't want to go WOT anymore. I found a midway point on the throttle that would go just fine and felt almost as fast as WOT, but if I went passed that point it would bog. I tied it at the dock and reved it with the seat off. It would rev really high (don't know RPM b/c tach doesn't work) then sound almost like a rev limiter and bog down from there. Any ideas as to what is causing this. It was running good when I stopped riding it last Tuesday and now these problems today. If it is my high speed screws the problem is that one of them is stuck and will not turn. Any info is greatly appreciated.
Thanks,
Kevin
Thanks,
Kevin
