Got this race ski with tons of mods. I think I may have figured out my problem. Because the pistons are new I have been mixing the oil about 35 to 1 for a nice break in mix. Well it keeps running for a while then barely running at all. At first glance when you look in the bow you can see that the oil injector has been blocked off. The tube that has the filter on it has been blocked, so I assumed that being a race ski that it was a pre mix ski. Upon farther investigation I have seeen two lines from the oil resevoir coming out and attaching to the block. Would this mean that the system is still operational? It has oil in the resevoir.
Would modifications to the motor dictate the blockage of the oil filter line and leaving the othet two lines attached?
Matt
Matt
