I have been in the process of draining the last guy's regular oil and replacing it with synthetic.
I changed the oil filter and lines, drained the tank, but I have a question about the return line from the engine to the top of the tank.
This hose still has regular oil, is it safe to disconnect from tank and drain. Should this line have oil in it in order for it to be safe to start.
Is it necessary to do a oil pressure check as it states in the manual? If I bleed the lines to remove any air bubbles how do I know when there are no more? Am I looking for major air gaps or what?
Thanks for the help.
