New SBT. I had a problem getting the exhaust to seal.. water leak.. but new gaskets fixed that.
3rd tank of gas, and the **** thing just does not have any torque. have to lift the nozzle out to get up to speed, and I am off 7 mph.
I do not have a tach.. so I do not know the RPM
Carbs kit done. Plugs look good on low and high chops. Starts good, runs good. I ran the screws in the RAVE caps down tight, and it does not help. it is a dog, it just will not pick up RPM.
I suppose you are going to tell me to remove the intake again and check the clearance on the plate? and the timing ..
I tripple checked the timing, but did not take the time to check plate clearence.. it is a new plate and the cover appeared good to go.
some insight please, I am flustered.. old motor ran great, right up until it ate the wrist pin needles..
I will need to check on a few things to get better answers.. like the true compression, and I might have the local wrench check the electrical timing..
but any thoughts on this would be accepted
[ July 17, 2003, 01:37 PM: Message edited by: Cheekster ]
