I am going to check ignition timing with timing light . Taken carbs off and sending them to water craftmagic for overhaul. Getting 6 new plugs. Check the magneto cup for wrong setting if timing is off. Check all hoses . Check out exaust for unrestricted air flow . Can any one think of anything els i need to look for while i go back thru process. Should this fix the fouling of the plug in the mag cylinder. Any more suggestion to look for will be greatly appreciated. Thanks guys
Check list
Just making sure i have everthing and nothing else i need to check i have all replies printed on what to check but when they dont work i new thing to check pops up. Sorry for your incoveince<a href="http://www.leximotorsports.com" target="_blank">www.leximotorsports.com</a><br />606 TEAM LEXIMOTORSPORTS<br /> <br /><br />2004 RXP
I understand. I have a list of replies from you and bill. I want to have everthing i need before i pull motor to find this small problem i have . I am going to test everthing you have gave me . Thanks again. If you know of anything i need to check for misfiring please let me know .<a href="http://www.leximotorsports.com" target="_blank">www.leximotorsports.com</a><br />606 TEAM LEXIMOTORSPORTS<br /> <br /><br />2004 RXP
