Hello, on my 96 GTI i have discovered that i had a leak around the oil bath fitting on the intake side beneath the rotary valve. my question is on pressure: is there a lot of pressure when the engine is running on this fitting or perhaps i recall it's just under the forces of gravity...
also, concerning the oil pump. tomorrow after work i am going to test the oil pump while it's hooked to the oil line that has the filter on it. i was going to take my dremel electric drill and put a soft felt tip on it and run it counterclockwise on the oil pump gear while hooked to the oil line. should this work and if so should oil flow out of the 1/8 inch lines?
thank you in advance.
