580 cdi testing
  • 580 cdi testing
    What readings should be found when testing a 580 (big magneto housing) cdi, rectifier and speed limiter? It can be done with a multimeter?
    Not all of it can be tested with a multimeter. Only the stator, and the wire looms. The ignition can be tested with an ignition tester.
    What is your problem ?
    A very common problem with that model 580 is a broken wire between the CDI and the coil. It won't look broken though, and may even test good until it wiggles.
    Bill O'Neal WCM
