Results 1 to 4 of 4
    johnd is offline Showing off on the beach
    Feb 2001
    Buffalo NY
    25
    Default
    ever since I installed my sbt 2nd. fuel pump kit on my 93 sl650, the idle speed changes. It won't idle, i adjust it, it cools down and I have to lower the idle back to normal. The cable has slack, and if I disconnect the setup and go back to stock, it's OK. any ideas anyone.
    Feb 2001
    Clearwater, FL
    7,358
    Default
    How exactly did you pipe the kit? What cable are you talking about? You don't adjust any cable when installing the new pump...what exactly do you mean 'let it cool down' - describe exactly what happens.
    Feb 2001
    Buffalo NY
    25
    Default
    I first thought the throttle cable may not have had the correct slack at the finger trigger, it was not tight. the pump was hooked up as on the kit supplied diagram, front carb using the new pump, back two carbs using the original pump. If I adjust the idle correctly when cold, once the machine is driven for a while, the idle drops so the ski stalls instead of idleing. I raise the idle so it idles, then when the machine cools off totally, the idle is too high. I have the mixture screws (low, all three 1/4 out) high, using the staggered polaris settings) Do I still have to have all 3 high speed carb screws at 3 different settings? everthing is hooked up using the supplied Tee fittings and hoses. Really weird Huh?
    Feb 2001
    Clearwater, FL
    7,358
    Default
    Your individual carb setting will be determined by what the engine needs, not by the book. You must fine tune them. See this guide for instructions.
  1. 3 outlet Mikuni fuel pump on Polaris SL650
    By kevmor99 in forum Polaris
    Last Post: 08-30-2005, 08:51 PM
  2. Polaris fuel pump kit
    By UniBougie in forum Questions about SBT
    Last Post: 04-09-2001, 11:38 PM
  3. polaris extra fuel pump
    By johnd in forum Questions about SBT
    Last Post: 02-24-2001, 07:26 PM
