Results 1 to 7 of 7
Thread: flywheel help
    Apr 2003
    carrollton ga
    236
    Post
    just ordered my new 657 but i cant ge3t my flywheel off i tried popping it with a heavy hammer no luck.and yes i took the nut off!any other secrets?
    21,545
    Post
    to get the flywheel off you need to use a universal flywheel puller. Also it is easier if you can use an impact wrench.
    May 2003
    Spain
    36
    Post
    Hey!! be carefully you need a flywhell puller to remove it, check the Removal/instalation Guide on the WEB are a very good Pics.
    Have a fun
    Apr 2003
    carrollton ga
    236
    Post
    i am using a puller,but to no avail; i will try the impact wrench thanks
    Apr 2003
    carrollton ga
    236
    Post
    is the thing that hard to get back on?
    21,545
    Post
    There is no effort to getting it back on, it just slips on. 5 seconds of propane heat also helps - don't go longer or you will damage your stator.
    Apr 2003
    Gainesville GA
    379
    Post
    mine was very tight and hard to get off. I thought i could not wrench it any tighter so i used a pole to extend the torgue on wrench . you want know its coming off untill it pops off.
    <a href="http://www.leximotorsports.com" target="_blank">www.leximotorsports.com</a><br />606 TEAM LEXIMOTORSPORTS<br /> <br /><br />2004 RXP
  1. 580 Flywheel Identification
    By RZMike in forum Sea-Doo
    Last Post: 06-22-2007, 11:11 PM
  2. pulling off 787/800 flywheel
    By radiocontrolhead in forum Sea-Doo
    Last Post: 10-03-2005, 12:24 PM
  3. Replies: 4
    Last Post: 10-02-2004, 02:25 PM
  4. Flywheel Removal, bad break
    By cat770r in forum Tigershark
    Last Post: 04-24-2004, 07:05 PM
  5. Flywheel Broke?
    By avlnche in forum Polaris
    Last Post: 07-03-2003, 02:55 PM
