expansion tube
  • expansion tube
    there is an insert in one end of the expansion tube on an XPL. Does the insert go toward the waterbox or the engine?
    What is "an expansion tube" ? Describe the "insert".
    Are you talking about the expansion chamber?
    What make and model Sea Doo are you talking about?
    Bill O'Neal WCM
      I'm sorry, the parts breakdown calls it an expansion tube. On a 98 or 99 XPL there is a tube that runs beside the gas tank, it connects the tuned pipe to the water box. one end of the tube looks thicker than the other it looks like there is an insert inside of it. I need to know which end faces the engine, and which end faces the waterbox.
        Match up the inside diameters of each connector hose to the correct outside diameter on each end of the tube.
        Bill O'Neal WCM
          That makes sense. Thanks.
