Results 1 to 5 of 5
    Jun 2004
    3
    Post
    I have a 2003 gtx sc, with a grand total of 6 hours or so and all of a sudden there is a distinct lack of performance. Usually it would yank a skier right out of the water, now it just drags em and is accompanied by the overheating beep. Rpms peg when going from a standing start and it is just a dog out of the hole, cavitating pretty impressively. Once on plane the max speed is down about 6 mph as well. If I make sharp turns it will overheat as well. BTW, dealer says wear ring looks "just broken in" and impeller looks fine. Any ideas?
    May 2002
    Michigan
    254
    Post
    The supercharger clutch is a problem. They have a kit to replace it with one that has ceramic washers. After it's replaced they also recommend using mineral oil in the motor as the new clutch doesn't like the synthetic oil.
    Jun 2004
    3
    Post
    What are the classic signs of the supercharger clutch being bad?
    Feb 2001
    Glendora, Ca.
    5,204
    Post
    You described the problem in your opening post. Lack of performance.
    Bill O'Neal WCM
    May 2002
    Michigan
    254
    Post
    Like Bill say's lack of performance. When you start out the SC spins up and as soon as it starts to work hard the clutch starts to slip. There are some special tools involved in getting it right so it's not an average backyard job.
  1. 2003 Sea-Doo GTX Check Engine problem
    By iolaus in forum Sea-Doo
    Last Post: 09-29-2019, 02:37 AM
  2. 2003 GTX Pump
    By Miquel in forum Sea-Doo
    Last Post: 06-02-2007, 03:58 PM
  3. Ran 2003 GTX with drain plugs open
    By hhellings in forum Sea-Doo
    Last Post: 07-04-2006, 11:02 AM
  4. 2003 GTX sc cavitation problem
    By Terry Coolidge in forum Sea-Doo
    Last Post: 04-07-2005, 03:44 PM
