Results 1 to 5 of 5
    Jun 2003
    Cleveland, Ohio
    14
    Question
    I failed to remove the PTO flywheel before the engine was completely disassembled. Now I have to replace an o-ring on the crankshaft bearing nearest to this flywheel, and have to remove it. How do you recommend doing this? The manual that I have recommends mounting a puller on the front flywheel and turning the PTO flywheel off. However, it does not go into detail. I cannot see any bolts or anything else holding the PTO flywheel, so should I remove it using the impeller tool?
    21,545
    Post
    stop the rear cylinder using rope in the plug hole. Use a chain wrech and breaker bar to remove the pto
    Jun 2003
    Cleveland, Ohio
    14
    Post
    I meant completely disassembled, down to the crankshaft. What do you suggest now?
    21,545
    Post
    You need to put the crank in a large vise to hold it.
    Jun 2004
    Columbus Ga.
    16
    Post
    I did this myself . Even though I had a big vise and a big table,I had to apply heat to the fly wheel to break it loose.
  1. removing the pto flywheel
    By 95xp720 in forum Sea-Doo
    Last Post: 07-05-2007, 12:33 PM
  2. 580 Flywheel Identification
    By RZMike in forum Sea-Doo
    Last Post: 06-22-2007, 11:11 PM
  3. 580 Port Timing (Yellow vs. White)
    By ehiebert in forum Sea-Doo
    Last Post: 04-16-2007, 06:55 PM
  4. Installing PTO & Flywheel
    By CGAux in forum Sea-Doo
    Last Post: 03-30-2006, 12:51 PM
  5. Removing PTO & Flywheel on 787
    By JimZ in forum Sea-Doo
    Last Post: 07-15-2003, 02:42 PM
