Ok, a little help on a carburator question please. I have a 93 SPX, and the engine starts up just fine if I pour about a teaspoon of gas in each carb and then dies when that gas it burned. However, it won't fire up by itself with gas from the gas line. I pulled the hose and it's clear, and the gas in the tank is good. If I empty the filter, it fills back up pretty quick, so I know the gas from the tank is making it to the MAG carb.
So, if I'm right it's a problem with the gas flow inside the carburator. Is that correct. Is it likely this problem would be corrected with a carb rebuild kit?
Or, can it be a plugged carb-to-carb hose or carb-to-gas tank hose?
Any help would be appreciated.
